    Issues configuring GPIO
    GamePad/GPIO/USB encoder
    configuring gpio
    • Multiface II+
      Multiface II+ last edited by
      Hi,
      I'm a new user of RECALBOX, I plugged arcade controllers on the GPIO of the RPI3.
      I made a test with "evtest", everything is well recognized :
      GPIO 1
      L = type 1 (EV_KEY), code 304 BTN_SOUTH, value 1
      R = type 1 (EV_KEY), code 315 BTN_START, value 1
      A = type 1 (EV_KEY), code 314 BTN_SELECT, value 1
      CREDIT/SELECT = type 3 (EV_ABS), code 1 (ABS_Y), value 1
      START = type 3 (EV_ABS), code 0 (ABS_X), value -1
      HOTKEY = type 3 (EV_ABS), code 0 (ABS_X), value 1
      GPIO 2
      UP = type 1 (EV_KEY), code 315 (BTN_START), value 1
      DOWN = type 3 (EV_ABS), code 0 (ABS_X), value 1
      LEFT = type 3 (EV_ABS), code 0 (ABS_X), value -1
      RIGHT = type 3 (EV_ABS), code 1 (ABS_Y), value 1
      B = type 3 (EV_ABS), code 1 (ABS_Y), value -1
      Y = type 1 (EV_KEY), code 307 (BTN_NORTH), value 1
      X = type 1 (EV_KEY), code 310 (BTN_TL), value 1
      But, when i'm back in es i can attribute only half of my controllers, for example :
      UP, DOWN, LEFT, RIGHT, B, X, Y... But the others controls are not responding
      recalbox.conf is configured as :
      controllers.gpio.enabled=0
      controllers.gpio.args=map=1,2
      I lokked in :
      es_input.cfg
      But everything seems ok.
      Maybe i miss something
      Thank you in advance for the answers.
        Zing Global moderator Translator @Multiface II+ last edited by
        @multiface-ii See if this helps:
        https://forum.recalbox.com/topic/24422/no-sound-on-splash-screen-and-gpio-doubt/4
