    Hidden Cave Story port if preinstalled games are hidden
    Your recalbox
    hidden cave story port preinstalled are
    2347
    • F0XHOUND
      F0XHOUND last edited by
      The title says everything. In prior versions Cave story was displayed when preinstalled games are hidden.
      Not now 😞
        Zing Global moderator Translator @F0XHOUND last edited by
        @f0xhound You can access via SSH the path //recalbox/share_init/roms and copy the games you want in this case.
        Se a minha resposta foi Ăștil, por favor, dĂȘ um voto positivo, clicando na seta para cima logo abaixo da resposta, ao lado de "citar".
        Mad-Soft 1 Reply Last reply Reply Quote 0
        • Mad-Soft
          Mad-Soft @Zing last edited by
          @zing i have the same problem with 7.2.2
          In /recalbox/share_init/roms/ports/Cave Story is cavestory with the game. It comes with the build image. But not show in emulationstation.
          Others like wolfenstein, quake, doom.. already display.
          I don't have option "hidden preinstalled...." activated
            Zing Global moderator Translator @Mad-Soft last edited by
            @mad-soft This indicates that cavestory is being recognized like all other emulators: if there is no game, it is not displayed.
            Add some games, or copy them from the folder I mentioned above.
            • Mad-Soft
              @zing I don't understand why not display CaveStory in Ports menu of EmulationStation
              How.....
              A picture is worth a thousand words
              This is my share/roms/ports -> https://pasteboard.co/K9E17bb.png
              This is my share_init/roms/ports -> https://pasteboard.co/K9E1WE1.png
              What's wrong?
                @mad-soft
                Sorry, I hadn't been able to test it so far, but I finally had the time and conditions for it:
                Cavestory appears if the option to hide preinstalled games is disabled, and cavestory is hidden when the option to hide preinstalled games is active.
                There is some other kind of problem with your setup, I recommend you try doing a factory reset.
                @Mad-Soft @F0XHOUND Check out this topic (in French, use google translator):
                • https://forum.recalbox.com/topic/24266/jeux-ports-avec-la-7-2-1/5
                If you wish, open an issue, reference this post, and copy the issue link created in this post, so that all users with this complaint can support the issue:
                https://gitlab.com/recalbox/recalbox/-/issues
                • Mad-Soft
                  @zing Thank you very much.
                  I try factory reset ...
                  101.4k
