    Moonlight on PI4 with 7.2.2 - best practice
    moonlight pi4 7.2.2 practice
    • Zemus
      Zemus last edited by Zemus
      Moonlight is working again under 7.2.2 , but only in sdl mode (software decoder)
      There is a fix on the way for the hardware decoder, but it isnt out yet.
      What does this mean? 1080p 60 fps doesnt work (unless you like artifacts)
      You get the best results if you set your moonlight.conf to the following values:
      codec= h264 (h265 is gray flickering all the time)
      width = 1920
      height = 1080
      fps = 30
      or if you want 60fps:
      codec= h264
      width = 1280
      height = 720
      fps = 60
      thats all 🙂
      (everything testet in LAN mode)
      100.9k
