    Unsolved iJoy NoName Controller 005 successfully pairs but can't configure it
    GamePad/GPIO/USB encoder
    ijoy noname 005 successfully pairs cant configure
    2139
    • brenscar2020
      brenscar2020 last edited by
      Hi
      I have an iJoy NoName 005 Universal Controller, similar to this: https://www.nordstromrack.com/s/ijoy-all-in-one-wireless-controller-white/n3020433
      I'm using a Raspberry Pi 3 B+, with Recalbox 7.2.1
      I can successfully get it to pair to the controller, but when I go to Configure a Controller, and I hold down any button on the controller, nothing happens.
      I've already tried changing the drivers from bluez to official and shanwan, and none of those drivers worked. I also tried enabling the GPIO driver and the Steam controller and I can't get it working with any of those drivers.
      I've tested the controller on windows, and it works on Steam no problem, so I know the issue is not with the controller.
      Would anyone be able to help me getting this controller to work with Recalbox please.
      Thanks
        Zing Global moderator Translator @brenscar2020 last edited by
        @brenscar2020 There is a possibility that this control is not compatible.
        With cable, does it work?
        You can test it:
        https://recalbox.gitbook.io/documentation/tutorials/controllers/configuration-test/test-your-joystick-with-sdl2-jstest
        brenscar2020 1 Reply Last reply Reply Quote 0
        • brenscar2020
          brenscar2020 @Zing last edited by
          @zing hi
          I tested it with a cable - same problem. It won't accept any input
          I suspect it's not supported.
          • brenscar2020
            brenscar2020 @brenscar2020 last edited by
            @brenscar2020 tired sdl2-jstest, and the controller isn't listed when it's connected via USB
              @brenscar2020 Sorry, but unfortunately your joystick is not compatible, you can open an issue, but there won't be an immediate solution:
              https://gitlab.com/recalbox/recalbox/-/issues
              • brenscar2020
                @zing great thanks
