    Nacon + Dreamcast
    GamePad/GPIO/USB encoder
    nacon dreamcast
    1144
    • RB2021
      RB2021 last edited by
      Hi all,
      I use a nacon pad with a dreamcast game (rayman 2) . The emulator is melting two buttons : the left stick up movement and pad up button. So when pushing up the stick, the character is at first doing the up pad function.
      I tried the same game on N64 and it works perfectly.
      Any idea ?
      Thanks a lot
      RB4 + RB 7.2.1 + Nacon Pad.
        Zing Global moderator Translator @RB2021 last edited by
        @rb2021 Have you tried to change the emulation/core?
        RB2021 1 Reply Last reply Reply Quote 0
        • RB2021
          RB2021 @Zing last edited by
          @zing thanks for your answer.
          yes I tried, but it seems only one is available for dreamcast...
          • cdtpepette
            cdtpepette last edited by
            Try to disable digital to analog in retroarch button config.
            Raspberry pi 4 2Go,RGBDual, Recalbox 8.1-64bits, share sur NAS nfs Yunohost (raspberry pi 3).
            Gpi Case Rpi 0 µSD 32Go Recalbox 8.1
            • RB2021
              RB2021 @RB2021 last edited by
              @rb2021 thanks for the idea. But.... how can i do that ? in some menu ?
              cdtpepette 1 Reply Last reply Reply Quote 0
              • cdtpepette
                cdtpepette @RB2021 last edited by
                @rb2021 hotkey + b
                • RB2021
                  RB2021 @cdtpepette last edited by
                  @cdtpepette it works perfectly ! thanks 🙂
