    Please add SwanStation/DuckStation to Pi Zero image
    Testers's corner
    please zero
    • Hilarious
      Hilarious last edited by
      Greetings everyone!
      I recently tried DuckStation on an old x64 netbook (dell mini 1012), and it performs better than pcsx-reamed.
      The under-clocking option for the psx cpu helps to make more games playable.
      For example castlevania s.o.n. works fine in duckstation but its too slow on pcsx reamed.
      Im no sure but maybe DuckStation can be added to de pi zero image to make possible psx emulation.
      On my gpi case, the standalone pcsx rearmed carsh and the libretro core is too slow with sound cracking.
      im using recalbox version 7.2.1 on both machines.
      Best regards!
        Zing Global moderator Translator @Hilarious last edited by
        @hilarious Sorry, but it's not that simple.
        If an emulator is available for one type of hardware, but not available for another (example: SwanStation is available for Rpi3, but not for RPi0), it means that there is some kind of problem with this emulator in this hardware, and the developers decided to remove the emulator to avoid these problems.
        If the emulator is already integrated in Recalbox on other hardware, this indicates that it is not so difficult to add it, but, it does not make sense when the performance of this emulator on this hardware is below expectations.
        I understand that there is a problem with pcsx rearmed in the GPi case as you mentioned, but adding another more problematic emulator is still not a solution, it is more feasible for developers to focus on fixing the pcsx rearmed problem.
        When and IF SwanStation performs well at Rpi0, it will be added, but if the performance is lower than expected, it will never be added.
        • Hilarious
          Thanks for your answer Zing!
          its a new emulator to me, so i wanted to share what happend on my netbook.
          But i understand your point, hopefully pcsx reamed can be fixed on the gpi case.
          Greetings!
