    V3.2.9-beta5 : let's test
    v3.2.9 beta test zx spectrum
    11
    31
    11498
    • digitaLumberjack
      Hi, i released the 5th beta of v3.2.9. What's new in 5th beta :
      • Added a full system for libretro fba. No more switch. This decision has been made because there are too many differences between piFBA and libretro to use only one of them.
      • Added xboxdrv support up to 4 players
      • Corrected the fba bug with xbox360 controllers (i hope so i cannot test)
      What's new :
      • <del>Added fba emulator switch in recalbox.conf, now you can choose between piFBA and libretro FBA (defaults are piFBA for RPi1, and libretro FBA for RPi2)</del>
      • Added snes9x, catsfc, pocketsnes switch in recalbox.conf
      • Added virtualboy platform
      • Fixed : buttons on axis in retroarch config
      • Added timestamps in logs
      • Fixed xboxdrv pacakge
      • Added wpa_supplicant on rpi1
      So what it means : libretroFBA support many games, including ...... STREET FIGHTER 3 ! I tested it on RPi2 it runs very well. On RPi1, i did not test. fixed issues : https://github.com/digitalLumberjack/recalbox-os/issues?q=milestone%3Av3.2.9+is%3Aclosed I need your feedbacks 🙂 AND YOUR SCREENSHOTS OF YOUR VICTORIES ON SF3 ! If you install it, please try to test most of the new features and report any bug... http://archive2.recalbox.com/recalboxOS-v3.2.9-beta5.zip
      • dale_coop
        dale_coop last edited by
        Bonsoir retroboy, J'ai testé cette version sur mon rp1 (installation sur SD fraichement formatée en FAT32), notamment pour mon souci de wifi (wpa_supplicant not found on certain rpi #138) maintenant voici l'erreur dans le log : /recalbox/scripts/recalbox-config.sh: line 260: /usr/sbin/wpa_supplicant: No such file or directory Ai vérifié, dans le dosser /usr/sbin, j'ai effectivement pas wpa_supplicant. ++ dale
        • zool_80
          zool_80 last edited by
          Bonjour, je viens de créer un topic dédié avec ma solution qui semble fonctionner pour le pad filaire xbox 360 et quelques extraits de fichiers (je ne voulais pas polluer ce thread) Maintenant le pad fonctionne parfaitement chez moi et est configuré automatiquement sous retroarch (le post se trouve dans dépannage en français). Bonne nuit à tous! Je pense avoir réglé le soucis des boutons L2 et R2, les raccourcis magiques de la croix directionnelle (qui ne fonctionnaient pas: save state increase, decrease, rewind, ...) et enfin la configuration automatique de l'intégralité de la manette sous retroarch. Je peux me tromper, je vous laisse le soin de tester et vérifier. Je reste bien sur dispo si besoin, Amitié et encore bravo pour recalbox!
          • digitaLumberjack
            @dale_coop yes i don't know why i just see that wpa supplicant is not compiled...
            • digitaLumberjack
              @dale_coop ca devrais etre ok avec la beta que je viens de mettre en ligne
              • nickdj
                nickdj last edited by
                Can't wait to test this out. It's great seeing so many frequent updates and each one really makes a difference.
                RPi 2 Not overclocked Edimax EW-7811UN LogiLink BT0007A USB bluetooth V2.1 PS3 Controller RecalBox v3.2.8
                • imaster
                  imaster last edited by
                  Il n'y a pas moyen d'activer les mise à jour vers les versions beta dans les menus? Je ne peux pas m'amuser à chaque version beta à faire une nouvelle installation complète.
                  • digitaLumberjack
                    Et moi je ne peux pas m'amuser a chaque version a créer un système de mise a jour vers les beta 🙂 Sachant en plus que les gens vont l'activer, le laisser actif et que si ca plante le système lors d'une mise à jour ca va criser 😄
                    • imaster
                      Oui, je comprends cette réponse et je m'y attendais. Et bien tant pis.
                      • idarius
                        idarius last edited by
                        Plop, perso depuis la dernière maj officielle, de 2 ou 3 jours, plus aucun soucis avec les manettes sans fil xbox. L2 et R2 détecté d'office, ainsi que le bouton "home", qui ne l'était pas auparavant. d'autre part, la connexion de la manette lançait xbmc, ce bug a aussi disparu. bref félicitation pour tes améliorations fréquentes, c'est un régal 🙂 Concernant l'intégration d'hypérion, tu saurait si c'est galère, et a quand je pourrai m'y attendre? j'utilise recalbox sur mon rasp 1 au lieu de mon 2 à cause de ce manque 😛 merci !
                        • zaybacker
                          zaybacker last edited by
                          Retroboy, j'ai une question, tu as modifié quel fichier pour ajouter le lancement de kodi depuis le menu?
                          • digitaLumberjack
                            Sur emulationstation ? https://github.com/digitalLumberjack/recalbox-emulationstation/blob/recalbox-buildroot/es-app/src/guis/GuiMenu.cpp Faudrais que je fasse un peu de refactoring dessus, il devient trop gros 🙂
                            • imaster
                              Y a une beta3?
                              • zaybacker
                                Ha ouais c'est dans le code source, j'ai passé 2h à lire tous les scripts de la distrib.... xD je teste quelques choses et jte soumet l'idée si ça fonctionne.
                                • zaybacker
                                  Bon voila j'explique. J'ai essayé Scummvm, mais tous les jeux ne passe pas, par exemple discworld 2 tu as pleins de fichiers! Du coup il le prend pas en compte. L'idée ça serait de pouvoir lancer scummvm depuis le menu start, pour ensuite utiliser l'interface de Scummvm pour ajouter des jeux. La j'ai lancé depuis le terminal, j'ai ajouté Discworld 2 et il la reconnu!
                                  • zaybacker
                                    Sinon j'arrive pas à forcer la résolution en 720p game_hdmi_mode=4 Ma TV se met en 1080i
                                    • digitaLumberjack
                                      T'as fais tvservice -m @zaybacker ? Le mode est bien supporté ? Pour scummvm t'as bien fait comme indiqué la : https://github.com/digitalLumberjack/recalbox-os/wiki/Manual-(EN)#b---scummvm-games ?
                                      Y a une beta3?
                                      Oui il y a une beta 3 mais quasiment rien de changé, c'était pour moi.
                                      • m0i
                                        m0i last edited by
                                        Bonsoir, La manette de PS3 officielle en filaire n'est toujours pas reconnu.(RPi1 B) Est-ce normal ? Merci
                                        • zaybacker
                                          T’as fais tvservice -m @zaybacker ?
                                          heu j'ai juste édité le fichier de config partagé avec samba. De tête j'ai mis mode 4 en 720p, j'ai une vieille TV HD 720p, le mode 1980i ça a toujours étais chelou avec...
                                          • zaybacker
                                            In this folder, you will have to add a single file, named [gameshortname].scummvm
                                            Certes mais dans discworld 2 tu as multitude de fichier, je peux pas renommer un fichier.scummvm à la louche, et si je lance scummvm depuis le terminal, en utilisant leur interface, ça fonctionne nickel si j'ajoute le dossier DW2. Bon ma manette (maudite) X360 fonctionne pas avec mais ça c'est un autre problème. D’ailleurs penses tu que ça serait possible de rajouter Dosbox aussi, vu que moi le rétrogaming c'est principalement des vieux jeux PC.
