    Recalbox 4.0.0 beta 2 manual overclock on RPi 3 ?
    4.0.0 beta overclock
    6
    10
    7331
    • slowmo310
      slowmo310 last edited by
      Is there a way to do this without relying on the front-end ?
        Not for the moment, we need to practice stability tests before adding an overclock setting.
        • slowmo310
          So I wouldn't be able to go into raspi-config from a prompt and do it myself ?
          • slowmo310
            Any update on an OC option ? I opened this as a issue on github, and it was deleted by a mod. I wonder if this will eventually be addressed.
              Issue closed not deleted. https://github.com/recalbox/recalbox-os/issues/806
              • slowmo310
                Hello Acres, would you know by chance if it can be manually done without the front-end ?
                • nickdj
                  nickdj last edited by
                  You can overclock via the configuration (hold shift when booting) and there are many examples out there where the cpu_free can be increased a little and the sdram freq upped to 500.  These settings work well. If I remember correctly there is a config file somewhere where you can predefine an overclock setting ( currently set as 'none')  I'll have a play and tell you what works well setting wise and where the configuration file is.
                  RPi 2 Not overclocked Edimax EW-7811UN LogiLink BT0007A USB bluetooth V2.1 PS3 Controller RecalBox v3.2.8
                  • slowmo310
                    OMG, Thank You !
                    • ulrich453
                      ulrich453 last edited by
                      nickdj, Any update on setting wise on what works best? Thanks,
                        voljega Banned last edited by
                        https://github.com/recalbox/recalbox-os/issues/896 resumed and translated from french : after tests on 20 different Pi3, configurations are : arm_freq=1400 (Extrem) / 1350 (High) / 1300 (Normal) over_voltage=4 sdram_freq=575 sdram_schmoo=0x02000020 over_voltage_sdram_p=6 over_voltage_sdram_i=4 over_voltage_sdram_c=4 core_freq=500 v3d_freq=500 h264_freq=333 gpu_mem=256
