    Problems after automatic update 7.2 on Raspberry PI 4B
    7.2 automatic update
    6
    6
    1753
    • papay
      papay last edited by papay
      Thanks to the developer for the update, but there were problems.
      Strong brakes in PSP and PSX. In KODI, the TV constantly switches to another source. When navigating the menus and selecting games, the system often freezes or a black screen appears, only a forced restart helps. A clean install didn't fix the problem.
      I understand that it takes time to fix the problems of the new version, but they made it impossible for me to use the system.
      Is it possible to download version 7.1.1 today?
      Zing 1 Reply Last reply Reply Quote 1
        Zing Global moderator Translator @papay last edited by
        @papay
        Use the default theme to avoid problems, and on Kodi, check this out:
        https://forum.recalbox.com/topic/23883/radpberry-pi4-kodi-black-screen-7-2/7
        No, it is not possible to download previous versions.
        • heavyamarillo
          heavyamarillo last edited by heavyamarillo
          i have same issue, even using default theme, system get freeze many times (most of them under mame ), so as it seem there is no way to downgrade ealier useful version (7.1.1), i guess we need to wait until developers fix the issues
          SkySlicer 1 Reply Last reply Reply Quote 0
          • SkySlicer
            SkySlicer @heavyamarillo last edited by Zing
            @heavyamarillo
            (Admins feel free to delete this if its not okay.)
            I have 7.1.1 backed up on Google Drive for all platforms. I rolled all my devices back to this version as I find 7.2 unusable in my use case.
            DELETED
            • Space81
              Space81 last edited by
              Hi, on my rpi 3b + with joysticks connection via gpio, I had some big problems on the PSX emulator that I have reported here: https://forum.recalbox.com/topic/24033/rb-7-2-on-rpi-3b- psx-emulator-gpio-problems, even the audio disappeared in the menu but I didn't have freeze, I still went back to my backup version of 7.1.1, I can't deprive my son of the PSX emulator, I will update to 7.2 when there it will be better times
                On Pi4, there are a known problem with PPSSPP regarding freezes and lag ingame. PSX is optimized and works better. Check your roms.
