    NEO GEO @ recalbox 4.0.0 beta 2
    xbox360 control neogeo unibios imame4all mame2003
    • tr1plx
      tr1plx last edited by
      Hi Folks, I'm using a RPI2 with recalbox v3.3.0-beta17 with a couple of neogeo-games. Working fine with the following config: ## NeoGeo emulator ## You can use pifba or a libretro core (fba2x,libretro) neogeo.emulator=fba2x ## If you set libretro as neogeo.emulator, uncomment the line below and set the retroarch core (fba,imame4all) ;neogeo.core=imame4all I set up a new SD-Card with recalbox 4.0.0 beta 2 (newest Version today) with the same config and same neogeo-Roms but they aren't working at all. Are there some changes in Version 4, maybe the neogeo.zip Bios File ? Can anyone provide me a Hash-Sum please ? I have several ROMsets - so which emulator is best choice for Neogeo-System?
      • chamilonster
        chamilonster last edited by
        i was read here https://github.com/recalbox/recalbox-os/wiki/Add-system-bios-(EN) this: Néo-Géo : If you want play to neogeo's games, you need to add bios inside the rom folder associated to the emulator used.
          voljega Banned last edited by
          Maybe yor neogeo BIOS has an uppercase extension .ZIP ? There's a known bug in 4.0.0 with that rename it to .zip and it should work again For any infos on arcade on the Recalbox, please read the two github wiki pages related to arcade
          • tr1plx
            Thank you very much dude, you made my day. Renamed it from .ZIP to .zip and everything works fine 🙂   Yay... let's play some Metal Slug !
            • javier-arias
              javier-arias last edited by
              I have a similar problem, I just migrated to the latest beta. I had my neo geo games in the FBA dir, but now most of them aren't working . The rest of the FBA games are working fine.
              101.4k
