    connection and updates
    connection updates
    • burts_19
      burts_19 last edited by
      running recalbox 6.1.1
      on odroid xu4
      I'm trying to update to the latest version. ON-line guide suggests menu - updates - start update, but I don't seem to have the option to 'start update' as mentioned in the help.
      So i thought it might be my connection. I'm connected to router via ethernet cable, but the network status in 'not connected' - i've checked my passwords etc and added them a few times.
      what am i doing wrong? many thanks.
      DacK Zing 2 Replies Last reply Reply Quote 0
      • DacK
        DacK @burts_19 last edited by
        @burts_19 You can't update to Recalbox 7.x.x from Recalbox 6.x.x.
        You'll have to start all over and write the new 7.1.1 image on your uSD. (hopefully, for the last time)
          Zing Global moderator Translator @burts_19 last edited by
          @burts_19 As mentioned above, it is not possible to upgrade from very old versions to the latest version, a clean reinstall is required.
          Maybe this will help:
          https://www.youtube.com/watch?v=skeULeTu7p8&list=PL2oNQ0AT7fx2ExiSNrfHUzga5GnogI4sh&index=23&ab_channel=Recalbox
          • burts_19
            thanks guys, appreciate the response.
            clean reinstall complete.
            i'm a real novice at all this - i apologise.
            i've added my ROMs back on but lost my scraped images. trying to use the in built scraper, it scrolls through the ROMs and identifies them, but doesn't pull the image. error at the end advising issue with download.
            xu4 is connected via ethernet to router and network settings shows 'connected'.
            i've tried using ARRM too via desktop, but even though the desktop picks up RECALBOX on the network, ARRM doesn't seem to. i type in the route directory manually, and ARRM does pick up the ROMs but the images don't pull through.
            burts_19 1 Reply Last reply Reply Quote 0
            • burts_19
              burts_19 @burts_19 last edited by
              @burts_19
              problem solved, used wireless dongle, which connected and images scraped using in built scraper.
              thanks again and apologies.
