    Controller works in emulationstation but not in games
    GamePad/GPIO/USB encoder
    6992
    • fanboy
      fanboy last edited by
      I have an xbox 360 wireless controller that works fine in ES, but doesn't work with any emulators.  Tried looking for a way to access retroarch (I'm assuming that's what is being used for most of the emulation), but if it exists, I haven't found it yet.
      • nosfay
        nosfay last edited by
        To enter RetroARCH Menu, hit "hotkey" + "B" or "A". But your controller should be OK if you can use it on ES... Maybe you should try to remap all buttons manually in ES controllers menu.
        • fanboy
          I can't access retroarch menu with “hotkey” + “B” or “A”.   Guess I'll have to figure it out manually. thanks for response.
            Hello in recalbox.conf : https://github.com/recalbox/recalbox-os/wiki/recalbox.conf-(EN) disabled ps controller enable only xboxdrv controller
            controllers.ps3.enabled=0
            ## Choose an driver beetween official, shanwan and gasia if you have dualshock clones (official,shanwan,gasia)
            controllers.xboxdrv.enabled=1
            reboot rpi , configure gamepad into emulationstation try again in game
              And for information by default, hotkey is mapped on central xbox button (power on switch).
              • fanboy
                Thanks guys...editing recalbox.conf did the trick.   I've messed around with other Raspberry Pi OSs, but I'm a noob to recalbox.  Even with editing the .conf, it is still the easiest to setup so far.
