    Audio channels selector in audio menu (Stereo or mono)
    audio channels selector stereo mono
    • Danixu86
      Danixu86 last edited by
      Hello,
      I've seen that GPi case is configured on downmix mode by default. Is correct because the speaker only uses the right channel and the best is to mix both into mono. The problem comes when I use headphones, the audio still on downmix mode and sounds strange.
      For now I'm using this options in /etc/asound.conf:
      pcm.monocard{
              slave.pcm "hw:0"
              slave.channels 2
              type route
              ttable {
                      # Copy both input channels to output channel 1 (Right).
                      0.1 1
                      1.1 1
                      # Copy both input channels to output channel 0 (Left).
                      0.0 1
                      1.0 1
      pcm.stereocard{
              slave.pcm "hw:0"
              slave.channels 2
              type route
              ttable {
                      1.1 1
                      0.0 1
      pcm.!default monocard
      I change the default route between monocard and stereocard, but is very annoying because I have to connect to the RPi through ssh, mount the root as RW and change that file every time I want to change between modes, so I want to know if is possible to add an option in Audio menu to allow the user to change between mono and stereo sound.
      Thanks!
        Zing Global moderator Translator @Danixu86 last edited by
        @Danixu86 I recommend that you open an issue in gitlab:
        https://gitlab.com/recalbox/recalbox/-/issues
        Danixu86 1 Reply Last reply Reply Quote 0
        • Danixu86
          Danixu86 @Zing last edited by
          @Zing said in Audio channels selector in audio menu (Stereo or mono):
          Ok, thanks!! I'll do it 😁
