    PC88 - Games not running with External Disk
    Emulator Arcade/PC/Console
    pc88 running external
    • jerome38000
      jerome38000 last edited by
      Hello,
      PC88 games are running well after a fresh Recalbo 7.1.1 install on SD Card (roms directly in the SDcard - RPI4), but not if the roms are placed in an external USB Disk.
      This external Disk has been built by Recalbox system just after SDcard fresh install
      I put the same bios in the Sdcard and in internal system (oricutron dir).
      Ex : 1942 (1987)(ASCII).d88
      Thanks.
      • jerome38000
        quasi88, not oricutron, my bad
          Zing Global moderator Translator @jerome38000 last edited by
          @jerome38000 I have no way to test it, but, no other user has reported any problems like that, you are probably using a poor quality USB Disk, with low read/write speed (but I'm not sure).
          Perhaps the formatting of the USB Disk can also influence.
