    Save cheat in retoarch ?
    Emulator Arcade/PC/Console
    cheat retoarch
    • Hotday
      Hotday last edited by
      Raspberry Pi model: 3B+
      Recalbox version (build) : 7.1.1
      Matériels (Micro SD, Power Supply, etc.): Micro SD class 10 (32 GB)
      Manette(s): Logitech F310
      Good evening everyone,
      In retroarch, is it possible that the cheats selected and applied to the Rom are automatically launched with the Rom in question? Or is it necessary to reload these cheats each time you launch them?
      Another question:
      in retroarch ->Quick menu -> Cheat
      there is the button "save cheats as (save current cheats as a backup file)". When we select it, a name of our choice is to be filled in. Does the extension have to be typed? If yes, does it have to be .cht? Because I can't load it.
      Thanks to you!
        Scavy Global moderator @Hotday last edited by
        @Hotday hello,
        please do not open several topic for the same subject.
        https://forum.recalbox.com/topic/23505/sauvegarder-cheat-dans-retoarch
        I close this one.
