    Modify Video snap position
    Themes & Interface
    modify snap position
    • Mamoles
      Mamoles last edited by
      Hello,
      I've modified the "Notalic" theme and it now suits me well.
      As you know, you're never finished with Recalbox and i decided to add video snaps.
      Videos play well but not as the same position as the cover.
      For instance, I modified the xml file for Atomiswave in order to put the exact same values for md_video as i did for md_images, but changing values don't affect video position.
      Thank you for your help.
        Zing Global moderator Translator @Mamoles last edited by
        @Mamoles I am not as knowledgeable about creating themes, but, I recommend that you contact the original author of the theme so that he can help you, or, check another theme in which this function suits you, and copy the configuration.
        I recommend that you use only updated themes from this section, the "Next Pixel" theme is the most recommended.
        • Mamoles
          Thank you for your answer.
          I will use the "Next pixel" theme in order to enjoy videos.
          Do you know how to disable video snaps in a specific theme ? so i could enjoy videos in "Next Pixel" and enjoy my modified theme without videos.
          Thank you.
            @Mamoles Sorry, I don't know if this is possible.
            Mamoles 1 Reply Last reply Reply Quote 0
            • Mamoles
              Mamoles @Zing last edited by
              @Zing
              Hello, i found a solution.
              I actually tried to modify the xml file for each system and did not work.
              In fact, i only had to modify the md_video value in the theme xml.
              Have a great day.
              101.4k
