    Odroid Go Advance - Stuck at Welcome Screen
    Emulator Arcade/PC/Console
    odroid advance stuck welcome
    2480
    • Grimlock42G1
      Grimlock42G1 last edited by
      Hello my dear friends,
      I just flashed Recalbox 7.1.1 onto an sdcard and put it in my Odroid Go Advance. It booted up, but doesn't react to any buttons I press except the power butten, thap puts it into sleep mode.
      Any ideas?
        Scavy Global moderator @Grimlock42G1 last edited by
        @Grimlock42G1 Could you post a photography of your Odroid Go Advance ?
        • Grimlock42G1
          Grimlock42G1 last edited by Grimlock42G1
          Yes, I can. 🙂
          Batocera and Emuelec work fine.
            @Grimlock42G1 oki, it's an OGA2.
            Did you install recalbox 7.1.1 ?
            What is your sd card ? A sandisk one, samsung one, a generic one ?
            Mine is working fine using RCB V7.1.1 and a Sandisk card. I installed it using RPi-imager.
            Did you check the buttons ? Are they well connected ?
            • Grimlock42G1
              I flashed RB 7.1.1 to a 128gb sandisk ultra using balenaetcher.
              I also have a 32 gb sandisk with Batocera 29 which is working fine. So I don't think it's a hardware issue.
                @Grimlock42G1 Ok, can you try using RPi-manager, we sometimes get problems with etcher.
                If the pb remains, can you post a support archive please ?
                Using internet, connect to : http://recalbox/help
                • Grimlock42G1
                  Unfortunately the results are the same when flashing the image via Pi Imager.
                  • Grimlock42G1
                    I found this in the changelog for the next release:
                    • Fix Odroid Go Advance controller (v1)
                    Might be the problem.
                      @Grimlock42G1 So, just be patient and wait for the next-release, it may solve your controller problem. 👍
                      • Grimlock42G1
                        I found the gitlab commit in the beta11 branch. I just needed to ad a few lines to the es_input.cfg in system/.emulationstation/ .
                        Now 7.1.1-reloaded works. This might help every other odroid go advance (v1) user. It has to be added before </inputList> at the end of the file.
                          <!-- Odroid Advance Go Internal controler -->
                          <inputConfig type="joystick" deviceName="odroidgo2_joypad" deviceGUID="19000000010000000100000001010000" deviceNbAxes="2" deviceNbHats="0" deviceNbButtons="16">
                            <input name="joystick1up" type="axis" id="1" value="-1" code="1" />
                            <input name="joystick1left" type="axis" id="0" value="-1" code="0" />
                            <input name="lum-" type="button" id="14" value="1" code="708" />
                            <input name="lum+" type="button" id="15" value="1" code="709" />
                            <input name="vol-" type="button" id="12" value="1" code="706" />
                            <input name="vol+" type="button" id="1" value="1" code="707" />
                            <input name="left" type="button" id="8" value="1" code="546" />
                            <input name="down" type="button" id="7" value="1" code="545" />
                            <input name="right" type="button" id="9" value="1" code="547" />
                            <input name="up" type="button" id="6" value="1" code="544" />
                            <input name="r1" type="button" id="5" value="1" code="311" />
                            <input name="l1" type="button" id="4" value="1" code="310" />
                            <input name="y" type="button" id="3" value="1" code="308" />
                            <input name="x" type="button" id="2" value="1" code="307" />
                            <input name="b" type="button" id="0" value="1" code="304" />
                            <input name="a" type="button" id="1" value="1" code="305" />
                            <input name="hotkey" type="button" id="10" value="1" code="704" />
                            <input name="select" type="button" id="10" value="1" code="704" />
                            <input name="start" type="button" id="11" value="1" code="705" />
                          </inputConfig>
                        annunaki 1 Reply Last reply Reply Quote 1
                        • annunaki
                          annunaki @Grimlock42G1 last edited by
                          @Grimlock42G1
                          Thank you for this!
                          FYI, there is a typo on line 8. The id should be 13, not 1. The volume up button did not work until I changed the value.
                          So far, all else seems to work as it should.
