    Change PSX default emulator
    Emulator Arcade/PC/Console
    default
    • Jailer
      Jailer last edited by
      Like the title says, is there a way to change the default psx emulator? I can change for each individual game in the menu but it is rather tedious to change for many games. Libreto PCSX_REARMED doesn't work with the hardware I'm running it on.
      Jailer 1 Reply Last reply Reply Quote 0
      • Jailer
        Jailer @Jailer last edited by
        Disregard, I found it in the settings.
        Voo2 1 Reply Last reply Reply Quote 0
        • Voo2
          Voo2 @Jailer last edited by
          @jailer
          And where in the settings? I have the same problem. I wonder why people always write that the problem is solved, but not where they found it to help other.
          • Alvin
            Alvin Banned @Voo2 last edited by
            @voo2 said in Change PSX default emulator:
            @jailer
            Is it so hard to find ?
            Main Menu -> Advanced Settings -> Advanced Emulator Configuration
            Chose the System you want and you can change Emulator & Core for all Games !
