    Can y put roller coaster tycoon on my recalbox ?
    Emulator Arcade/PC/Console
    rtc game pc 64 bits
    1062
    • RetroNat
      RetroNat last edited by
      Hi !
      Just a little question, can I put rtc (the 1 or the 2, I don't care...) to my recalbox ?
      Thank you in advance !
        Zing Global moderator Translator @RetroNat last edited by
        @RetroNat Only if it is a ROM, from any Console, that the hardware supports according to the compatibility table:
        https://recalbox.gitbook.io/documentation/hardware-compatibility/emulators-compatibility
        If it fits the above parameters: Yes.
        If it's a windows game: No.
        If in the table it says that your hardware does not support: No.
        • RetroNat
          Oh 😲 so i cannot play rtc on my recalbox 😢 ... That's pity...
          • RetroNat
            BUT, if someone have any idea to run it on a normal raspberry pi with raspbian, I take it 🤗 !
              @RetroNat You can try with "Wine" or some other program that emulates windows on Linux distros.
              But, this is the Recalbox Forum, here we only support Recalbox, for this type of help, look for the Raspian forum:
              https://www.raspbian.org/RaspbianForums
              • RetroNat
                Ok ok sorry ...
