    Problem loading sav files in all cores?
    loading sav cores
    3857
    • 8bit_astronaut
      8bit_astronaut last edited by
      I am having trouble loading sav files in basically all the cores. I didnt made any changes.... and this trouble happened from one day to another. Please someone help me
        Hello, What version of recalboxOS ?
        • 8bit_astronaut
          4.0.0 beta on pi 2 without overlock
          • DAM
            DAM last edited by
            I used the 4.0 and don´t have problem to save and load. Maybe file corrrupt ?
            • 8bit_astronaut
              Wich file should i edit? I dont want to make a clean install again :C
              • nosfay
                nosfay last edited by
                If you try to use a new save file, does it work? (rename your save .old, dont delete it)
                • 8bit_astronaut
                  The only think that work well is the save state and auto save feature
                  • nosfay
                    Did you try what i said ? Do you have an error like "save file corrupted" when you try to launch your game ?
                    • 8bit_astronaut
                      Hmmmm no, nothing appear, also, the sav file just dont load. I checked in my pc with an emulator an all sav files are fine 😕
                      • nosfay
                        But if you rename your actual save file in OLD, does the emulator create one new with your game name?
                        • 8bit_astronaut
                          Yes, it generates a new Sav file, a functional one, but doesnt load it. Sadly, i cant say how to replicate this....bug, because i dont know how it happen. I didnt know...i doesnt hard reset the pi, i always wait to turn off to disconect the energy source, and the config file looks fine. I thinked it could be the emulationstation config file, but i could find it. Btw, i find a config file for gpsp, and looks corrupted, but i checked in the instalation files and looks corrupted too.
                          • nosfay
                            Maybe your files are on read only ... I dont see other solution. You should try to ask on IRC.
