    Moving Rom Files From MicroSD To USB HDD
    Your recalbox
    hdd moving rom usb
    • tdelios
      tdelios last edited by tdelios
      My microSD card contains a lot of roms in different folders including the cover arts and video clips from the subfolders.
      I bought myself a 4TB USB HDD and moved all files and sub-folders from the rom folder from the MicroSD card to the USB HDD.
      After I rebooted the Pi, the cover arts and video clips for the games I have are gone. Only the generic listing of games for each console is listed.
      Do I need to edit each gameslist.xml to point to the USB HDD or is recalbox have a bug to support cover art images and video clips from USB HDD?
        Hello
        you need to edit gamelist.xml to check path files.
        tdelios 1 Reply Last reply Reply Quote 0
        • tdelios
          tdelios @acris last edited by
          @acris said in Moving Rom Files From MicroSD To USB HDD:
          Hello
          @acris
          That seems like a lot of work. Any good editors I can use to speed this up?
          Metramo 1 Reply Last reply Reply Quote 0
          • Metramo
            Metramo @tdelios last edited by
            i now have edited the emulationstation's es_systems.cfg in share to the exact path from the ssd, but it not worked. that would be awesome, if such a easy way exists 😉
            101.0k
