    Solved Exit psx games in 7.1.1
    Emulator Arcade/PC/Console
    7.1.1
    1622
    • sklammer2k
      sklammer2k last edited by sklammer2k
      Hey guys,
      I just upgraded my box (Raspberry 3b+) to 7.1.1 and now I can't exit any psx game via hotkey + start so I have to restart my box. I use the PCSX_Rearmed emulator. Is there anything I can do to fix this?
      Thanks für your help
        Hello
        reconfigure your gamepad in Emulationstation menu
        sklammer2k 1 Reply Last reply Reply Quote 0
        • sklammer2k
          sklammer2k @acris last edited by
          @acris i did that several times with different controllers but no success. In other emulators like n64 i have no problems. Do you have an idea what could help?
          Thanks for your help.
            which gamepad
            • sklammer2k
              @acris It's an Xbox Elite Controller 2 I had a try with an normal usb snes gamepad and there the hotkey works. Is there a way to get the hotkeys working with my xbox controller?
              • sklammer2k
                It seems that i've found a workarround. I mapped the Hotkey to the xbox button and now I can exit psx games like expected.
                Thanks in advance for your support and keep up that great work 🙂
