    Just reporting the performance of the PSP games Guilty Gear XX Accent Core Plus, Tales of Eternia and Fate/Unlimited Codes in a Raspberry pi 4 and LR PPSSPP
    Emulator Arcade/PC/Console
    libretro performance ppsspp raspberry pi 4
    • sergioad
      sergioad last edited by sergioad
      Hello friends just reporting Guilty Gear XX Accent Core Plus and Tales of Eternia do not play that well on LR PPSSPP,in fact GGXXAC has choppy audio
      In the contrary and surprisingly Fate/Unlimited Codes plays perfect with some very occasional hiccup even being a fully 3D game
      My setup is a pi 4 8 GB model with a Cooler master pi case 40 overclocked with the following parameters
      arm_freq=1950
      gpu_freq=700
      over_voltage=6
      gpu_mem=256
      I am also using OpenGL FKMS
      If you are starving for a modern-ish fighting game with long chains and frenetic adrenaline pumping action your best bets are BlazBlue Continuum Shift II, BlazBlue Continuum Shift Extend or Fate/Unlimited Codes, stay clear of Guilty Gear XX Accent Core Plus, and for action RPGs YS Seven is your best bet if you are using LR PPSSPP
      I know the standalone PPSSPP (it is a rule on most emulators) things run much better than in Libretro but a friend told me it did not ran well on his pi 4 4 GB and standalone PPSSPP
      Note: I am currently using RetroPie, but either way I wanted to share my discoveries as I did in the RetroPie forum and I did not wanted to keep you without the knowledge as I see it as a resource to be shared and I am doing so
      How Guilty Gear XX Accent Core Plus runs on Recalbox? Have you managed to make it run on either LR PPSSPP or the standalone one? If it dpes please let me know and I will get Recalbox right away
      100.6k
