    Issue with Bios while using external Data storage for PSX
    bios data external issue storage
    • GutsNaem
      GutsNaem last edited by GutsNaem
      Hello everyone and sorry to bother you.
      Before taling about the problem I precise that I followed the guide to use external datastorage for Roms and that I put BIOS files both in the recalbox bios folder and in the external datastorage bios folder.
      When I use only the SD card with Recalbox, the PSX works perfectly fine and the games too. No issue at this point.
      When I connect to the external Data storage, the system tells me the bios are missing but when I check, the Bios are present in both : \RECALBOX\share\bios & \ASGARD-RETRO\share\bios (ASGARD-RETRO is the name of my External DataStorage)
      I wanted to know if someone had a solution or knows of the issue please?
      Thanks everyone,
      Guts
      PS : I didn't find another post with this issue but if someone already asked please excuse me for asking again 😕
      EDIT : The solution has been found :
      Ok I found the solution I post it here if anyone needs it in the future :
      It's all my bad the Names where not in lowercase, and even if the uppercase does work without external datastorage it doesn't when using an USB Storage.
      GutsNaem 1 Reply Last reply Reply Quote 1
      • GutsNaem
        GutsNaem @GutsNaem last edited by
        @GutsNaem
