    HELP!!!!! Recalbox Fullscreen set up
    Your recalbox
    help recalbox fullscreen
    2734
    • recalboxfan
      recalboxfan last edited by
      Hi
      Can anyone help me with the fullscreen set up for Recalbox? I tried 4/3, 16/9 etc and the screen does not show full screen, I dont know what I done wrong... : (
      • olivierdroid92
        Hi
        We need more information to help you
        Are you using the last release 7.1.1 ?
        Are you running on a Rapberry Pi 3 ?
        • recalboxfan
          Hi Oliver,
          I used the lastest Recalbox firmware. I tried to change the size screen to 16/9, 4/3, auto etc and it does not go fullscreen. I even untick the overscan... Can you help me?
          • olivierdroid92
            Pi 0 or Pi 1 or Pi2 or Pr3 or Pi4 ou XU4 or PC ?
            TV or Compteur Screen ? CRT or LCD ?
            • airdream
              you have to disable "Pixel Perfect"
              recalboxfan 1 Reply Last reply Reply Quote 0
              • recalboxfan
                recalboxfan @airdream last edited by
                @airdream What are setting should I choose? 4/3, 16/9...etc?
                • airdream
                  airdream Theme moderator @recalboxfan last edited by
                  @recalboxfan
                  yes if your TV is 16/9, you have to set the same ratio
                  • recalboxfan
                    @airdream It is a bartop arcade machine, I tried to set it to full screen.
                    • airdream
                      and.... is it work or not yet?
                      try different ratio, without pixel perfect.
                      How is your TV resolution? do you run recalbox on Rpi? wich one?
                      101.0k
