    Atomiswave odd message
    Emulator Arcade/PC/Console
    atomiswave odd message
    • Fefo81
      Fefo81 last edited by
      Hi guys,
      When I start playing a game this message appears‘please upgrade to make romset or expect issues’. It happens with every game. I have got RP4 7.1.1
      What should I do?
      Thanks
      • barbudreadmon
        barbudreadmon @Fefo81 last edited by
        @Fefo81 said in Atomiswave odd message:
        The message is "Please upgrade to MAME romsets or expect issues", which i think is self-explanatory : you are currently using a deprecated rom format, and should be using latest MAME romsets and bioses instead.
        Libretro developper :
        • FBAlpha FBNeo (Arcade)
        • Kronos (Sega Saturn/ST-V)
        • YabaSanshiro (Sega Saturn)
        Fefo81 1 Reply Last reply Reply Quote 0
        • Fefo81
          Fefo81 @barbudreadmon last edited by
          @barbudreadmon thanks. Bios is updated so I need to replace roms. Got it
          • barbudreadmon
            Bios is updated
            Careful about that, those atomiswave roms you are using are actually naomi conversions running with a naomi bios (naomi.zip). The real atomiswave romsets require the real atomiswave bios (awbios.zip)
