    WIRED LAN WITH MANUAL SETUP
    wired lan setup
    • Gigi20
      Gigi20 last edited by
      There is a way to use the wired line insteed of the wifi,
      with manual IP GATEWAY MASK settings?
      There s way to do this?
      Thank You
      Giulio
        Zing Global moderator Translator @Gigi20 last edited by
        @Gigi20 Have you already tested whether configuring the parameters for wifi in recalbox.conf do not work for this situation?
        The parameters are:
        ;wifi.ip=manual ip address
        ;wifi.gateway=new gateway
        ;wifi.netmask=new netmask
        There is still this tutorial, but it may be out of date:
        https://recalbox.gitbook.io/tutorials/v/francais/reseau/ip/parametres-ip-manuel
        And, for some users, the easiest is to configure it on the internet router, and set the IP by the Rpi MAC address.
        loycemaes 1 Reply Last reply Reply Quote 0
        • loycemaes
          loycemaes Banned @Zing last edited by loycemaes
          This post is deleted!
