    2 problems : core2duo e6750 and N64 blackscreen, psx no hotkey button
    Emulator Arcade/PC/Console
    problems
    • Jürgen Löb
      Jürgen Löb last edited by acris
      Hello
      I have an core2duo e6750 without an graphic card it runs recalbox perfect but.
      N64 start only with black screen!
      And psx emu retroarch doesnt safe my hotkey button.
      I only have a ps2 style controller and there is no hotkey so i set it to f12 on my keyboard.
      But after every restart the config is gone.
      Any help
        @Jürgen-Löb said in 2 problems.:
        Uncompress your roms, check extension with readme.txt in /roms/n64
        Put hotkey on Select button , remap your controller in Emulationstation Menu > configure gamepad.
        and use select as hotkey
        • Jürgen Löb
          Jürgen Löb last edited by Jürgen Löb
          Thanks
          The n64 roms work peefectly on my raspberry 3b.
          The roms are not compressed and in a .n64 format.
          I try to change the buttons but it dont work. The first time i connectet the gamepad it was auto configured to select + start for exit and selct + x o ∆[] for menu.
          Then i reinstall it new because i use an bigger hdd and now it doesnt work automatic!
          • Jürgen Löb
            Edit...
            Now i managed to skip the select button...
            But it say hold an button for skip it doesnt work.
            So i tried arrow down on my keyboard and now it works.
            I skipped select and assigned select to the hotkey.
            but don't i need select for psx games??
            And why is retroarch set ESC =hotkey and ESC = exit.
            Possible change this to f12 or so for the next release.
            • Jürgen Löb
              Any more help with n64 ?
