    No network on Recalbox 7.1.1 x86_64
    network pc 64 bits network issue
    • Wirby
      Wirby last edited by
      Hello,
      I've just downloaded Recalbox 7.1.1 for x86_64. Games are working quite fine, but I have an issue with network : even though my PC is connected to my router using wired connection, the network configuration screen shows that I'm not connected, no IP is assigned to the ethernet connection.
      I have a recent PC, my motherboard is a MSI B550M Mortar, with a 2.5Gb/s ethernet port, so maybe Recalbox doesn't have any driver for this chipset ?
      Is there anything I can do to make my PC able to connect to the network ?
      Thanks in advance !
      • davidb2111
        davidb2111 Staff last edited by
        Hi @Wirby
        Unfortunately, seems your motherboard is a little too recent, but stay tuned for next release: We will provide update drivers and will add support for new network cards as well.
        David
        Wirby 1 Reply Last reply Reply Quote 0
        • Wirby
          Wirby @davidb2111 last edited by
          @davidb2111 Thanks for your answer, I'll wait for next release then 🙂
