    Dual Shock 2 detected as Dual Shock 3 and can't be full configured
    GamePad/GPIO/USB encoder
    dual shock detected cant full configured
    • martin87
      martin87 last edited by
      I got newest Recalbox on Rasberry 3b+ with Original Dual Shock 2 with adapter for USB connection. Recalbox can't detect press cross, square and circle in configuration gamepad window. also recalbox detect this gamepad (and/or adapter) as Dual Shock 3, not Dual Shock 2.
      lsusb
      Bus 001 Device 005: ID 054c:0268 Sony Corp. Batoh Device / PlayStation 3 Controller
      How can I fix this problem?
        Zing Global moderator Translator @martin87 last edited by
        @martin87 The fact that Dual Shock 2 is recognized as Dual Shock 3 probably happens due to the adapter used, and it is probably because of this same adapter that the buttons are not recognized correctly.
        You can test your joystick:
        https://recalbox.gitbook.io/documentation/v/francais/tutoriels/controleurs/configuration-test/testez-votre-joystick-avec-sdl2-jstest
        And manually edit the file:
        \share\system\.emulationstation\es_input.cfg
