    Upgrade to raspberry Pi 4
    upgrade
    • gesucristo
      gesucristo last edited by
      Hello everyone. I couldn't find this in the forum nor in the documentation, hope I didn't miss it.
      I was happily using recalbox on a raspberry pi 3B+.
      I now got a Pi4 and discovered that the very same SD card won't work on it.
      I then realized that for Pi4 there is a separate image.
      How can I upgrade the image so that it can run on a raspberry pi 4 without needing to reinstall everything (and copy roms and all my customizations and the like)?
      Thanks so much.
      • sroach
        sroach last edited by
        You'll want to look at moving roms, bios, configs to external usb storage. This will allow you to re-image the MicroSD card with pi 4 image of 7.11 and then when you plug the usb back in and point to it in storage settings your roms and bios's will be there.
        • gesucristo
          Yup, thanks for your reply. Unfortunately what you suggest is actually what I hoped to avoid: I have no extra storage for those ROMs other than the SD where they are right now.
          Also I made some bootcmd customizations, and other tunings as well, so I hoped to be able not to do everything manually again.
          So the only alternatives a far as I have understood are buying a new SD card and moving all the settings or sticking with Rpi3, right?
