    MAME Force close in 4.0.0
    mame force close 4.0.0
    4884
    • kenwong
      kenwong last edited by
      hello guys, I tried recalbox 4.0.0 (before that I played 3.3.0 b17) and I find that <DUNGEON MAGIC ver 2.10> will force quit after I press <left,right> to start. However I can run this game in 3.3.0 b17 with no same issue. what's the problem? Thanks a lot.
        voljega Banned last edited by
        Hello do you have bios or driver files with upper case extension .ZIP ? There is a known bug on 4.0.0 with that
        • kenwong
          Hi Voljega~ thanks for your help, I tried and still doesn't work. and if i change nxxxxx.zip to nxxxxx.ZIP . I can't run any game~. 😞
            No it's the opposite if you have .ZIP files you must change them to .zip
            • kenwong
              haha~ sorry I miss understand, however, I just feel wired this game will force quit after press "ok" but completely no problem in 3.3.0 b17 .
                well I don't know exactly I haven't tested arcade games much since installing 4.0.0
                • sneaker333
                  sneaker333 last edited by
                  I posted about the same issue with rainbow islands - however, the problem only seems to affect Pi2 and not Pi1
                  • kenwong
                    and only affect this game and not others. 😞 sad
                      So for the moment problems only with Rainbow Islands and Dungeon Magic ? I'll give it a try if I find a minute
                      • sneaker333
                        I think you can add Berzerk to the list - so I suspect there will be more titles affected
                          Shiiiit that's troublesome
                          • stuart-williams
                            stuart-williams last edited by
                            Not sure why these games aren't working for you. I've just tried all 3 you mentioned and all work perfectly for me using 4.0.0 beta 1 and default settings.
                            • sneaker333
                              @stuart - is that on a Pi1 or Pi2 ? - a clean install on both shows that they are working on my Pi1 but not on my Pi2
                              • stuart-williams
                                That's on pi2 Paul.
                                • sneaker333
                                  Just playing with this further and I think I've found the trigger - if I go into the main menu -> game settings -> advanced -> Mame and then turn off the rewind option then both Rainbow Islands and Berserk run fine. As soon as I turn that option on then they both bail straight back to the menu after the rom copyright screen.
