    Using 6.0 Themes in 7.x?
    6.0 themes 7.x
    • Tormentor667
      Tormentor667 last edited by
      Dear developers,
      is it possible to use 6.0 themes for Recalbox also in 7.x versions? And, where is a good place to download themes in general? Batocera has a nice feature inbuild, from where you can download themes directly in EmulationStation, that would be nice in Recalbox as well.
      Best regards,
      Torn
        Zing Global moderator Translator @Tormentor667 last edited by
        @Tormentor667 For a theme from an earlier version to work on a more updated version, you need to ask the theme author to update the theme, or, you need to update your themes, using the default theme as a base:
        https://recalbox.gitbook.io/documentation/v/francais/tutoriels/personnalisation-du-frontend/ajouter-des-themes-a-emulationstation
        If you prefer, download an updated theme in this section (currently, the most updated theme I know is Next Pixel theme, as you can read in the titles):
        https://forum.recalbox.com/category/14/themes-interface
        Tormentor667 1 Reply Last reply Reply Quote 0
        • Tormentor667
          Tormentor667 @Zing last edited by
          @Zing thanks kindly for the explanation, that will help me 🙂
