    Kernel panic after fresh install via NOOBS
    fresh kernel panic
    • jose1711
      jose1711 last edited by jose1711
      Hello, I took the latest NOOBS (3.5.0) and installed Raspbian Lite, OSMC and Recalbox on the same 64GB SD card. While the first two work fine, Recalbox is panicking with:
      Kernel panic - not syncing: VFS: Unable to mount root fs on unknown-block(179,2)
      Any idea? Cheers, jose
      Hw: RaspberryPi 3B+
        Hello @jose1711
        recalbox is not yet compatible with noobs.
        Need to wait 7.1 version.
        • jose1711
          Ah, thank you. That helps.
