    virtual boy games not centered
    Emulator Arcade/PC/Console
    virtual boy centered
    • neo207
      neo207 last edited by
      hello. i tried turning off overlay or changing its options. no change. so i don't believe the bezel is the reason as the game seems shifted to right/down - direction. any idea how i can change this, so that the image fits into the bezel/overlay?
      • olivierdroid92
        Hello
        Did you try:
        Aspect ratio = core provided ?
        neo207 1 Reply Last reply Reply Quote 0
        • neo207
          neo207 @olivierdroid92 last edited by
          @olivierdroid92 in the options i have "auto" for aspect , if it is what you mean. do i have to go to settings while the game is turned on? or should i find the option in the main menu of recalbox?
          • olivierdroid92
            olivierdroid92 Global moderator @neo207 last edited by
            @neo207
            No
            Lunch your game, then go in Retroarch settings
