    Raspberry Pi 4 8gb
    Community projects
    8gb
    • sirnomax
      sirnomax last edited by
      Hi!
      I have a question. Can recalbox supports the 8gb of ram of the raspberry pi 4 8gb?
      Thanks!
      • Pitch64
        Pitch64 Staff last edited by Pitch64
        Hi, I'm using the 8gb version of the rpi4 and it works fine. 🙂
        There is no benefit to have the 8gb, the only benefit would be to have another use of the rpi4 than recalbox (like 2 differents sd cards to use recalbox on one and another system on the other sd card).
        Next release? Soon™
        • sirnomax
          Thanks for the fast answer! But I've another question. If I wanna use dreamcast emulator, game cube emulator, and others newer than N64. I don't need the 8gb ram's version?
          Thanks again!
          • Pitch64
            The 8GB wont have any benefit. The best to use the rpi as a retrogaming system only is the 2GB, it can help only to read extracted ISOs only (ISO sizes are less than 2GB). There is no need to have so much ram for older systems.
            PS: there is no Gamecube emulator on rpi4.
            Next release? Soon™
