    X68000 and m3u files (limitations)
    x68000 m3u limitations
    • Claudio Cortes
      Claudio Cortes last edited by
      Hi!
      I'm creating "m3u" files to group "dim" mutidisk games for X68000 System. The maximum number of "dim" files per "m3u" is two? Because i'm trying to run "Aquales" game (3 disks, exclusive and hidden gem of X68000), and doesn't work (I change disk index with Hotkey+B, but doesn't work).
        Zing Global moderator Translator @Claudio Cortes last edited by
        @Claudio-Cortes I don't use this console, so I'm not sure, but, I found this documentation:
        https://docs.libretro.com/library/px68k/#multiple-disk-games
        You said that you already changed the disk index, but I highlight for the part: "The default disk drive that is swapped is FDD1. If you need to swap the disk loaded in FDD0, change the Core Option" Swap Disks on Drive "first before loading the new disk in this menu. "
