    Solved Possible bug on Advancemame on 7.1
    possible advancemame 7.1
    • Djoni Wes
      Djoni Wes last edited by
      Hi, I have downloaded the 7.1 version of the recalbox OS, testing arcades I found that Advancemame wasn't opening, done some dig here and discover the error was caused because of the "display_resize no" at advacemame.rc
      Changed 'no' for 'none' at /usr/lib/python2.7/site-packages/configgen/generators/advancemame/advMameControllers.py, at this line:
      finalConfig["display_resize"] = "yes" if system.config['integerscale'] == '1' else "no"
      And then it worked just fine
      Just posted to check if is a bug or just something in my recalbox
        Hello
        Bug Fixe ok
        Version NEXT
        News
        Add WPS support for quick WIFI configuration
        Improvements
        Improved NESPi4 case detection
        Libretro-atari800 with .car extension support
        Check free space before downloading updates
        Fixes
        Fix AdvanceMAME
        Fix broken WIFI on some Intel chips
        Bring back all firmwares
        Fix boot from SDH/HDD on rpi4
        Fix arcade hash calculations
        Fix game extension filtering
        Fix screenshots on x86/x64
        Fix multiple issues in ScummVM/ResidualVM: lag/crash on Pi4, joystick buttons, ...
        Source : https://gitlab.com/recalbox/recalbox/-/blob/master/RELEASE-NOTES.md
