    Raspberry Pi crackling / stuttering sound
    crackling stuttering sound
    2515
    • j7yzjhk28z
      j7yzjhk28z last edited by
      Hello,
      I've installed Recalbox 7 Reloaded on my Raspberry Pi 2. The interface is very good, and the background music is playing normally without any problem while in the Recalbox interface (game chooser, etc.).
      However, when I start a game (ex: a SNES game) the sound is distorded / crackling / stuttering.
      The FPS is quite high ( > 30).
      How to solve this?
      Thanks
        Scavy Global moderator @j7yzjhk28z last edited by
        @j7yzjhk28z hey !
        Are you using shaders?
        • j7yzjhk28z
          Thanks @Scavy for your answer!
          No I don't use any shader ; I don't know what it is.
          I just did a default RecalBox 7 installation.
          Steps to reproduce the error :
          • Take a RaspberryPi 2 (or maybe 3 as well)
          • Install RecalBox 7
          • Launch any super nintendo ('snes') game (in fact it's the same with megadrive games)
          • Use the default HDMI video/audio output
          • You will hear distorded sound
          • j7yzjhk28z
            Any idea @Scavy ?
              Zing Global moderator Translator @j7yzjhk28z last edited by
              @j7yzjhk28z Can you test with another HDMI cable?
              There are several versions of HDMI cables (1.1, 1.2, 1.3, 1.4, 2, 2.1), do you know which one you are using?
              Can you test it on another TV?
              Maybe this will help you:
              https://forums.libretro.com/t/bad-cracking-stuttering-sound-in-ra-with-any-system-or-game-with-vsync/15886
              • j7yzjhk28z
                Solved by using a RPi3 intead of RPi2!
