    x86_64 WiFi connection issues
    connection wifi x8664
    • GeneraleRusso
      GeneraleRusso last edited by GeneraleRusso
      Hello to everyone. I've been using Recalbox for quite some time on my RPi3B, but recently I decided to try it out on an old PC I had laying around, a Dell Optiplex 990 USFF.
      This system works perfectly, but because it has no integrated WiFi installed I tried connecting it with some USB wifi dongles.
      The problem is that all the 3 wifi dongles i could try, some of them don't work at all, some have very low speeds, others have inconsistent connection.
      So far I tested
      D-Link DWA-131 hw ver: E1, fw ver: 5.10 (Realtek RTL8192EU)
      TP-Link TL-WN725N (Realtek RTL8188CUS)
      Hamlet HNWU300N (Realtek RTL8192EU)
      I remember having issues with another dongle on my main PC with LinuxMint 19.3, a D-Link DWA182 D2 (Realtek RTL8812BU), of which i could build and install a set of drivers for the rtl88x2bu and made it work.
      Is there a way to install compatible drivers for the dongles i have? Or i'm better off using an ethernet cable just when i need to move stuff in and out of the system?
        Hello
        Issue open on github : https://gitlab.com/recalbox/recalbox/-/merge_requests/1238/diffs?commit_id=0c472fe88438f7ba1bccf0c56a4a79b5fdd29afc
        GeneraleRusso 1 Reply Last reply Reply Quote 0
        • GeneraleRusso
          GeneraleRusso @acris last edited by
          @acris Thank you. I guess with my current skillset i can only wait.
          • GeneraleRusso
            Small Update: at the list of non-working wifi dongles I can add:
            Generic chinese dongle (RL7601 chipset)
            D-Link DWA182 ver D1 (RTL8812BU chipset)
