    Problem with booting
    booting
    • Nickodem
      Nickodem last edited by Nickodem
      Hi, I use Raspberry Pi Zero with Recalbox on 8GB Sandisk's sdcard and sandisk 16gb pendrive which i use to boot and to have games on it (every game works fine from snes and nes). During the booting (from pendrive) it stops on black loading screen with these 4 pac-man ghosts. What am I supposed to do? I know that cleaning the pendrive and reinstalling it will help, but it often happens, I even changed the pendrive and it was still the same problem from time to time and it's very annoying. What should i do?
      Please help and thanks in advance.
      Nickodem Zing 2 Replies Last reply Reply Quote 0
      • Nickodem
        Nickodem @Nickodem last edited by
        @Nickodem ref
          Zing Global moderator Translator @Nickodem last edited by
          @Nickodem Watch this video (enable subtitles):
          https://www.youtube.com/watch?v=skeULeTu7p8&list=PL2oNQ0AT7fx2ExiSNrfHUzga5GnogI4sh&index=23&ab_channel=Recalbox
          You are probably facing some kind of incompatibility due to the different versions, as you can see in the video, to ensure that you have no problem, it is recommended to redo the scrape, to update the game lists. If you are trying to take advantage of a configuration file from an old version of the system, it is normal to have problems.
          The theme is also something that can cause problems, use the default theme to test, or use a theme that has already been updated to version 7.0: https://forum.recalbox.com/category/14/themes-interface
