    just loaded 7.0.1 fresh on a pi 4 scraper is not working
    loaded 7.0.1 fresh scraper
    3056
    • thanosazlin
      thanosazlin last edited by
      i guess i could manually copy what i have on my pi 3 sd card but just wondering why the 7.0.1 on my pi 4 is not working ? it's just skipping over all the games i have it set to refresh all games on all systems. i'm using a wired ethernet connection. not sure why it's not working anyone else having issues with 7.0.1 scraper ?
      • Pitch64
        Pitch64 Staff last edited by Pitch64
        Please see this topic:
        https://forum.recalbox.com/topic/21801/2020-10-17-screenscraper-information
        This scraper issue is not a recalbox issue but a screenscraper issue.
        Next release? Soon™
        • thanosazlin
          understood :).. another question so i have media dir with images, manuals, thumbnails, videos from my pi 3 with recalbox 7.0.1, i just copied the same media folder for all my game systems for some reason atari 2600 and 7800 and sega mega drive are now showing any images in the theme and i even switched back to the default recalbox theme :(.. all others like nes, snes, mame etc.. show my copied images from media folder/dir fine.. i don't know scratching my head here as the xml files look similar between all of them not sure what to look for, still doesn't explain why it wouldn't work just copying over a folder of png files from the pi 3 7.01 to the pi 4 7.0.1...
          • Pitch64
            When you copy the media directory, you need to copy the gamelist.xml file too. If your roms are exactly the same (same filename and same hash) and this file is added with the media directory, you should be able to see all medias in EmulationStation. This file is at the same level directory than your roms for each system. 🙂
            Next release? Soon™
            floridabjoern 1 Reply Last reply Reply Quote 1
            • floridabjoern
              floridabjoern @Pitch64 last edited by
              @Pitch64 Is there any way to produce this gamelist? I do have all the media, but the list got lost. Shure, I could write it by myself, but that would really be a mess.
              • Pitch64
                In RB menu, you can generate the game list. Go to a game listing, open the menu and choose to generate the game list (I'm not sure about the translation used, it's to recreate regenerate the game listings) 🙂
                Next release? Soon™
