    RPI3 XBOX 360 Wireless Controller N64 Issue
    GamePad/GPIO/USB encoder
    rpi3 xbox 360 wireless issue
    • Blingblang
      Blingblang last edited by
      Hi there,
      I've just updated my system on 7.0.1 and i still have the issue in N64 (i tested on Mario cart) i can't use L1 R1 button. I usually use R1 to jump and drift and it doesn't work at all neither on 7.0 or 7.0.1. It works like a charm on 6.1 though.
      • Blingblang
        I tried this trick; deleting /recalbox/share/system/configs/mupen64/input.xml given by @acris
        And it worked like charm.
        Merci @acris vous gérez chez recalbox
          Hello @Blingblang
          delete this file : /recalbox/share/system/configs/mupen64/input.xml
          reboot recalbox
          and try again. May be remapp your controller in emulationstation menu.
