    XBOX 360 USB WIRED CONTROLLER INGAME ISSUES
    GamePad/GPIO/USB encoder
    xbox 360 usb wired ingame
    1332
    • Chakarn
      Chakarn last edited by
      Hey Guys,
      I didn't find anything adressing this issue. My Controller doesn't work on Gamecube, Wii and some other Emulators. Works great in the Recalbox menu and emulators like GBA and so forth. Hope somebody can help me. Thanks 🙂
      My System:
      Intel NUC-Kit NUC6i3SYH
      Intel Core i3-6100U Prozessor
      Intel HD-Grafik 520
      8GB DDR4 RAM
      XBOX 360 USB WIRED Controller
        Hello
        try this idea :
        Go to Emulationstation Menu > gamepad options > configure gamepad and remapp your controller.
        Try again.
        Chakarn 1 Reply Last reply Reply Quote 0
        • Chakarn
          Chakarn @acris last edited by
          @acris This was my first thought as well and I tried it but with no success 😞
            We had a bug with somes fews xbox360 gamepad.
            It 's fix in recalbox 7.0.1
            • Add more hard-patched xbox pads
              https://gitlab.com/recalbox/recalbox/-/blob/master/RELEASE-NOTES.md
            this version is avaible tomorrow 21h00 (France) / 9.00 pm
            • Chakarn
              YESS Hopefully - if not I will write again 🙂 Thank You very much 🙂
              Greetings from Germany and keep up the good work
              • Chakarn
                @acris Unfortunately this one wasn't resolved either what I did now which helped with Gamecube at least is to Alt+F4 into dolphin and set up my Xbox Controller which immidiately resolved this issue at least in the Gamecube.
                Still trying to figure out the mapping for Wii though. Which is a bit tricky when Dolphin doesnt want to comply with simple mouse clicks. But perhaps this will help you fix this issue. I mean I had to set up the Controller inside of Dolphin perhaps you can automate this. 🙂
