    impossible to play with joypad in scummvm
    Your recalbox
    play joypad scummvm
    1276
    • Edu28
      Edu28 last edited by
      Hello, I am playing a graphic adventure, but it is being very difficult for me due to the sensitivity of the joypad of the remote control. Is there a way to use the keyboard and mouse in a traditional way?
        Scavy Global moderator @Edu28 last edited by
        @Edu28 Hi,
        yes, you can play all ScummVM games with a traditionnal keyboard & mouse. The experience is better, in my opinion. But... like amiga games, it seems there a little bug, mouse buttons are avaible, but the mouse cursor doesn't move. We're investigating 😉
        jorgemagana 1 Reply Last reply Reply Quote 0
        • Edu28
          the keyboard keys are not working correctly i'm playing indiana jones and the last crusade only works one of the keys to box the others or it goes forward or back
          • jorgemagana
            jorgemagana @Scavy last edited by
            @Scavy said in impossible to play with joypad in scummvm:
            @Edu28 Hi,
            Also, residual games do not start in pi 4.
              Scavy Global moderator @jorgemagana last edited by
              @jorgemagana yes, only avaible on PC... for instant.
              • Edu28
                @jorgemagana said in impossible to play with joypad in scummvm:
                No residual games, but if the specific versions for Scummvm, what surprises me the most is that it is a keyboard and mouse via usb cable
