    The scrolling sound has stopped working in version 7?
    scrolling sound stopped version
    1105
    • pajarorrojo
      pajarorrojo last edited by
      In recalbox 7 (raspberry 3) the sound of the scroll in the gamelist has stopped working, does someone else happen?
        Scavy Global moderator @pajarorrojo last edited by
        @pajarorrojo hi
        you're the first person that got the problem.
        Did it happen just after your fresh install ?
        Do you use an external support ? Hope you don't keep your 6.x configuration on your 7.0 version, otherwise that will cause problems for sure.
        pajarorrojo 1 Reply Last reply Reply Quote 0
        • pajarorrojo
          pajarorrojo @Scavy last edited by
          @Scavy Yes! fresh install and no overwriting configs. I'm a web programmer and i made my own theme with a custom sound scrroll, and this sound works well on 6.1.1 but not in 7. Testing another themes with scroll sound and same problem.
          • RetroVadus
            RetroVadus last edited by
            I can confirm it too in my custom theme. The scroll-sound can't be heard ussing the code:
            <textlist name="gamelist">
            	<scrollSound>./art/scroll2.wav</scrollSound>
            </textlist>
            Hardware: Raspberry pi 4b (4Gb)
            Controllers: Connected via GPIO
            Video: HDMI to RGB (1280x1024, 5:4)
            • pajarorrojo
              The bug continues in version 7.0.1, the scroll sound does not work, tested in Rasp 3B and also in Rasp 4B with the same result - The scroll sound works perfectly in Batocera 5.27.2, we rule out programming problem of the theme.
                @pajarorrojo @RetroVadus
                I report the bug.
