    Bugs on 7.0 (Rpi4 & PCx64)
    7.0 rpi4 pcx64
    1236
    • toniosj
      toniosj Spanish moderator last edited by
      BUGS RPI4 RECALBOX 7.0
      • Bad Default emulator for SNES (SNES9x 2002): Better another default one.
      • DOSBOX doesn't work. It reboots system when execute a game.
      • Shader selection doesn't nothing. If I select ZFAST, I don't see it inside game.
      BUGS PCx64 RECALBOX 7.0
      • Blackscreen when I execute a game. All systems. You can see it with nes.
      toniosj 1 Reply Last reply Reply Quote 0
      • toniosj
        toniosj Spanish moderator @toniosj last edited by
        (Edited)
        • Some DOSBOX game doesn't work. It reboots system when execute a game. (MDK)
        • Mouse doesn't work on DOSBOX games.
        • toniosj
          (Edited)
          • (SNES) Bad Default emulator for SNES (SNES9x 2002): Better another default one.
          • (DOSBOX) Some DOSBOX game doesn't work. It reboots system when execute a game. (MDK)
          • (DOSBOX) Mouse doesn't work on DOSBOX games.
          • (LIBRETRO) Shader selection doesn't nothing. If I select ZFAST, I don't see it inside game.
          • (DAPHNE) Buttons don't work
          • toniosj
            BUGS RPI4 RECALBOX 7.0.1
            • (SNES) Bad Default emulator for SNES (SNES9x 2002): Better another default one. (FIXED)
            • (DOSBOX) Some DOSBOX game doesn't work. It reboots system when execute a game. (FIXED)
            • (DOSBOX) Mouse doesn't work on DOSBOX games. (FIXED)
            • (LIBRETRO) Shader selection doesn't nothing. If I select ZFAST, I don't see it inside game. (FIXED)
            • Problems with VSYNC in SCUMMVM on RPi4. (NOT FIXED)
            BUGS PCx64 RECALBOX 7.0.1
            • (DAPHNE) Buttons don't work (FIXED)
            acris 1 Reply Last reply Reply Quote 1
              acris @toniosj last edited by
              @toniosj said in Bugs on 7.0 (Rpi4 & PCx64):
              Can you explain, the problem ?
              • toniosj
                toniosj Spanish moderator @acris last edited by
                @acris
                https://gitlab.com/recalbox/recalbox/-/issues/1279
                  @toniosj
                  ah oui la team cherche encore le problème. Thanks a lot.
                  • toniosj
                    @acris Merci à vous pour votre soutien au forum.
