    My Recalbox keeps crashing
    crashing keeps recalbox
    • 2ndCityCrusader
      2ndCityCrusader last edited by 2ndCityCrusader
      Hi, I'm new here, and I have a huge issue with my recalbox in my custom arcade cabinet. For some weird reason, the menu suddenly changed the theme to look like a traditional Rasberry black & white menu, but then when I changed the UI theme back to our custom setting, when I navigate the menu at times, the screen suddenly cuts to the bootup screen and locks up, which forces me to turn the console on and off. This happens every time when I'm trying to select a emulator! What should I do?
      Version: Dragonblaze 6.1.1
        Scavy Global moderator @2ndCityCrusader last edited by
        @2ndCityCrusader hello
        did you install the official recalbox OS, downloaded from this site ? did you install a custom theme ?
        Are your games/bioses installed on a external device ? If so, i suggest you make au fresh install.
