    Solved Is the built-in 6.1.1 scraper working properly?
    built-in 6.1.1 scraper properly
    • Kimba
      Kimba last edited by
      Hello,
      I scraped some PSX games on .cue/.bin format and it worked well, but I broke the entire system trying to do some things and had to reinstall it. Then, I tried to scrap the games again an says it did not find any system.
      Is there any configuration or thing I can try/check to make it work?
      Thanks!
      • Kintao
        Kintao last edited by
        SreenScrapper servers was down yesterday so just try again.
        It should work now they said everithing is up now.
        • Kimba
          Thank you so much! It works now.
