    How to add games through my network from Manjaro Linux?
    through network manjaro linux
    • Kimba
      Kimba last edited by
      Hi there!
      Is there a way to connect my laptop with Manjaro Linux to the Recalbox PC through my network in order to move some roms bigger than 300MB?
      Regards!
      sroach 1 Reply Last reply Reply Quote 0
      • sroach
        sroach @Kimba last edited by
        @Kimba
        https://forum.manjaro.org/t/howto-systemd-mount-unit-samples/1191
        if you hard coded the IP address of your Recalbox, put an entry in your /etc/hosts file so you can mount the name
        192.168.1.x. Recalbox
        then when you mount you can just call out Recalbox
        • Kimba
          Thank you for the information.
          Just realized I can type smb://recalbox on Manjaro's file explorer and the Share partition shows up!
          • sroach
            @Kimba Perfect, and as you add game roms then they will show up in ES.
